Up to 20% off select tools
Calculator is Stuck While Graphing
Views: 2.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
5
Past 30 Days:
36
All Time:
2,472
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
A graphing process may take long if the zoom is not appropriate, or the resolution is too high.
    1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: step 1, image 1 of 1
      • To cancel the graphing process, press the "ON" button.
      Ask FixBot
    2. Calculator is Stuck While Graphing: step 2, image 1 of 3 Calculator is Stuck While Graphing: step 2, image 2 of 3 Calculator is Stuck While Graphing: step 2, image 3 of 3
      • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
      Ask FixBot
    3. Calculator is Stuck While Graphing: step 3, image 1 of 1
      • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
      • The bar on the top right corner indicates the calculator is graphing.
      Ask FixBot
    4. Calculator is Stuck While Graphing: step 4, image 1 of 2 Calculator is Stuck While Graphing: step 4, image 2 of 2
      • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
      Ask FixBot
It is always a good idea to make sure your graph will display a good window.
Author
with
John Baek
31 Reputation
4 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 5
Past 30 Days: 36
All Time: 2,472
