Up to 20% off select tools
Cable set up
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
87
All Time:
1,577
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Very easy
Cable set up
    1. Cable set up, Cable set up: step 1, image 1 of 1
      • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
      • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
      • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
      Ask FixBot
    2. Cable set up: step 2, image 1 of 1
      • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
      • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
      Ask FixBot
    3. Cable set up: step 3, image 1 of 1
      • Insert power cable into socket.
      Ask FixBot
Finish Line
Author
with
Nikolai
281 Reputation
5 Guides authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 87
All Time: 1,577
