Cabinet Door Butt Hinge Replacement
    1. Cabinet Door Butt Hinge Replacement, Cabinet Door Butt Hinge: step 1, image 1 of 1
      • Determine where the cabinet needs repair: on the top or bottom hinge.
      Ask FixBot
    2. Cabinet Door Butt Hinge Replacement: step 2, image 1 of 1
      • Measure the hinge to make sure you have the correct size of your butt hinge.
      • Measure the distance between the screws and the height and width of the hinge to get the correct hinge.
      Ask FixBot
    3. Cabinet Door Butt Hinge Replacement: step 3, image 1 of 1
      • Remove the screws from the door with a Phillips #00 screwdriver and remove the hinge.
      • Keep the screws nearby; you will need them later.
      Ask FixBot
    4. Cabinet Door Butt Hinge Replacement: step 4, image 1 of 1
      • Align the cabinet door to stand straight with any surrounding cabinets.
      Ask FixBot
    5. Cabinet Door Butt Hinge Replacement: step 5, image 1 of 1
      • Place the new hinge where the previous one was. Align the holes together.
      Ask FixBot
    6. Cabinet Door Butt Hinge Replacement: step 6, image 1 of 1
      • Tighten the hinge into place using the same screws with your Phillips #00 screwdriver.
      Ask FixBot
If the door closes parallel to any surrounding cabinets, your fix is complete!
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 92
All Time: 1,922
