CRKD NEO S CK24NS Button Replacement
  1. CRKD NEO S CK24NS Button Replacement, Motherboard: step 1, image 1 of 1
    • Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
    Ask FixBot
  2. CRKD NEO S CK24NS Button Replacement: step 2, image 1 of 3 CRKD NEO S CK24NS Button Replacement: step 2, image 2 of 3 CRKD NEO S CK24NS Button Replacement: step 2, image 3 of 3
    • Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
    • Carefully lift off the back panel and set it aside.
    Ask FixBot
  3. CRKD NEO S CK24NS Button Replacement: step 3, image 1 of 3 CRKD NEO S CK24NS Button Replacement: step 3, image 2 of 3 CRKD NEO S CK24NS Button Replacement: step 3, image 3 of 3
    • Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
    • Take out the white plastic pieces connected to the motherboard with tweezers.
    • Gently lift the motherboard and set it aside.
    • If the small red plastic piece next to the audio jack falls out, don’t worry. You can pop it back into place during reassembly.
    Ask FixBot
  4. CRKD NEO S CK24NS Button Replacement, Button: step 4, image 1 of 2 CRKD NEO S CK24NS Button Replacement, Button: step 4, image 2 of 2
    • Depending on the button(s) you want to replace, lift them out with a pair of tweezers and put the new buttons in.
    • Make sure the controller is facedown because the buttons will fall out.
    Ask FixBot
Kailey Sillitoe
295 Reputation
2 Guides authored
1 Guide Comment
Where can one find replacement buttons?
Carlos - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 41
All Time: 537
