CR-10 V2 Linear Rail Kit Hotend Installation
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
79
All Time:
2,723
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
HE Adaptor Plate Stock CR10 V2/V3 installation guide
    1. CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: step 1, image 1 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: step 1, image 2 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Hotend Removal down: step 1, image 3 of 3
      • Remove the Hotend cover screw
      • Remove the Hotend mounting screws
      Ask FixBot
    2. CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: step 2, image 1 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: step 2, image 2 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Belt removal and Stock X Carriage: step 2, image 3 of 3
      • Loosen Idler pulley bracket screws and remove the idler pulley bracket
      • Remove the belt
      • Remove the lower V-slot wheel bolt from X-carriage
      Ask FixBot
    3. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: step 3, image 1 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: step 3, image 2 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting screw Pattern & Sliding on the Rail: step 3, image 3 of 3
      • Follow the table for the recommended mounting locations
      • Take note to skip 2 holes between fasteners, and make sure to mirror this process from each of the end of the rail until you meet in the middle.
      • For rails with an odd number of mounting holes, the pattern will overlap in the middle
      • For rails with an even number of mounting holes, the pattern will be continued across the rail
      • Pre-install all the M3x8 SHCS screw and Sliding T-nuts
      • Install the Printed T-nut guide on the end of the X axis extrusion, and slide the rail on to the X-axis from Right to left
      • The guide helps to slide the T-nuts into the extrusion
      Ask FixBot
    4. CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: step 4, image 1 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: step 4, image 2 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, Mounting the Rail: step 4, image 3 of 3
      • Slide the rail until you have about 2-3 mm between the rail and the end of the X axis extrusion.
      • Use both Linear rail Guide to center the rail to the Aluminum extrusion
      • Tighten the mounting screws as you go down. Making sure to slide down, slide the linear rail guide down as each screw is tightened.
      Ask FixBot
    5. CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: step 5, image 1 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: step 5, image 2 of 3 CR-10 V2  Linear Rail Kit Hotend Installation, X Carriage install: step 5, image 3 of 3
      • Belt adaptor
      • 4x M3x8 SHCS
      • 3x M3 split washers
      • M3 Hex nuts
      • Install the M3x8 SHCS screw with M3 Split washer in to the X carriage adaptor plate and mount to the Rail block.
      • Push up on the belt bracket, it is square against the bottom of the carriage block.
      • Note: If screws will not start, threading in. Spin the screws counterclockwise until you hear a click, and then tighten the screws evenly in an X pattern until they are fully tightened. This is to ensure that the threads do not get damaged.
      • Note, reference Hotend Mounting Instructions section before mounting the MGN 12 Adaptor Plates to the linear rail block. For installing Hex Nuts to the back of the Adaptors.
      Ask FixBot
    1. CR-10 V2  Linear Rail Kit Hotend Installation, Linear Rail Kit Hotend Install: step 6, image 1 of 1
      • All Stock hotend and extruder mounting screws are re-used for the CR10 V2/V2
      • M3x6 BHCS (+2mm longer than stock) screws are used to mount the stock Bl Touch bracket.
      Ask FixBot
AJ Pereira
2,744 Reputation
16 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
372 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 79
All Time: 2,723
