Up to 20% off select tools
CPU Fan Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
143
All Time:
1,749
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
CPU Fan Replacement
Tools
Introduction
Go to step 1 ↓
Cooling can become an issue for your computer when the fan is not able to get the job done, it can be slow or broken entirely. This guide will help you replace the slow or stopped fan to help reduce the temperatures in your computer.
    1. CPU Fan Replacement, Back Panel: step 1, image 1 of 2 CPU Fan Replacement, Back Panel: step 1, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
      Ask FixBot
    2. CPU Fan Replacement: step 2, image 1 of 2 CPU Fan Replacement: step 2, image 2 of 2
      • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
      Ask FixBot
    1. CPU Fan Replacement, CPU Fan: step 3, image 1 of 2 CPU Fan Replacement, CPU Fan: step 3, image 2 of 2
      • Remove the header by pulling on it with two fingers.
      Ask FixBot
    2. CPU Fan Replacement: step 4, image 1 of 1
      • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. CPU Fan Replacement: step 5, image 1 of 1
      • Remove the fan by moving it to the side and lifting it out of the computer.
      Ask FixBot
Author
with
Armani Tayeh
447 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 143
All Time: 1,749
