Community-Contributed Guide
Introduction
Go to step 1 ↓Thrustmaster sells spare part through their online Eshop.
You can also contact Thrsutmaster technical support to get spare part if not available in your region.
Tools
Unscrew the 5 screws shown in the first image
Unscrew the 4 screws shown in the second image
Turn the handle over and remove the black cover shown in the 3rd image.
Slowly pull the top half of the stick and rotate it. (Be careful not to damage the wires inside).
Disconnect the wires from CMS connector, they are highlighted in red.
Remove the screws so that you could detach the PCB.
Hold down the CMS clip which will allow you to remove the switch. If necessary, you can force it out or brake it.
Once the old CMS is removed, you can insert the new one
To reassemble your device, follow these instructions in reverse order. Be careful not to damage the wires when reattaching the two halves of the joystick handle.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
