CHUWI GemiBook XPro Lower Case Replacement
    1. CHUWI GemiBook XPro Lower Case Replacement, Lower Case: step 1, image 1 of 2 CHUWI GemiBook XPro Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
      • Orient the device to where you can see the bottom of the case.
      • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
      Ask FixBot
    2. CHUWI GemiBook XPro Lower Case Replacement: step 2, image 1 of 3 CHUWI GemiBook XPro Lower Case Replacement: step 2, image 2 of 3 CHUWI GemiBook XPro Lower Case Replacement: step 2, image 3 of 3
      • Insert an opening pick into the gap between the lower case and the chassis.
      • Pry along the entire perimeter of the laptop until the lower case fully releases.
      • Lift the lower case up and off of the chassis.
      Ask FixBot
Connor Bassolino
25,600 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 49
All Time: 408
