CHUWI GemiBook XPro Fan Replacement
    1. CHUWI GemiBook XPro Fan Replacement, Lower Case: step 1, image 1 of 2 CHUWI GemiBook XPro Fan Replacement, Lower Case: step 1, image 2 of 2
      • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
      • Orient the device to where you can see the bottom of the case.
      • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
      Ask FixBot
    2. CHUWI GemiBook XPro Fan Replacement: step 2, image 1 of 3 CHUWI GemiBook XPro Fan Replacement: step 2, image 2 of 3 CHUWI GemiBook XPro Fan Replacement: step 2, image 3 of 3
      • Insert an opening pick into the gap between the lower case and the chassis.
      • Pry along the entire perimeter of the laptop until the lower case fully releases.
      • Lift the lower case up and off of the chassis.
      Ask FixBot
    1. CHUWI GemiBook XPro Fan Replacement, Battery: step 3, image 1 of 2 CHUWI GemiBook XPro Fan Replacement, Battery: step 3, image 2 of 2
      • Peel off the black tape on the upper-right side of the motherboard.
      Ask FixBot
    2. CHUWI GemiBook XPro Fan Replacement: step 4, image 1 of 2 CHUWI GemiBook XPro Fan Replacement: step 4, image 2 of 2
      • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
      Ask FixBot
    3. CHUWI GemiBook XPro Fan Replacement: step 5, image 1 of 3 CHUWI GemiBook XPro Fan Replacement: step 5, image 2 of 3 CHUWI GemiBook XPro Fan Replacement: step 5, image 3 of 3
      • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
      Ask FixBot
    4. CHUWI GemiBook XPro Fan Replacement: step 6, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
      Ask FixBot
    5. CHUWI GemiBook XPro Fan Replacement: step 7, image 1 of 3 CHUWI GemiBook XPro Fan Replacement: step 7, image 2 of 3 CHUWI GemiBook XPro Fan Replacement: step 7, image 3 of 3
      • Lift the battery up and out of the chassis.
      Ask FixBot
    1. CHUWI GemiBook XPro Fan Replacement, Fan: step 8, image 1 of 2 CHUWI GemiBook XPro Fan Replacement, Fan: step 8, image 2 of 2
      • Use a spudger to push the fan connector out of its socket.
      Ask FixBot
    2. CHUWI GemiBook XPro Fan Replacement: step 9, image 1 of 2 CHUWI GemiBook XPro Fan Replacement: step 9, image 2 of 2
      • The copper piping can be damaged easily, so take care not to bend it.
      • Carefully peel back the black tape on the radiator.
      Ask FixBot
    3. CHUWI GemiBook XPro Fan Replacement: step 10, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the two 4.2 mm screws that secure the fan.
      Ask FixBot
    4. CHUWI GemiBook XPro Fan Replacement: step 11, image 1 of 2 CHUWI GemiBook XPro Fan Replacement: step 11, image 2 of 2
      • Gently lift the fan out of the chassis, with care not to strain the connected wire.
      Ask FixBot
    5. CHUWI GemiBook XPro Fan Replacement: step 12, image 1 of 2 CHUWI GemiBook XPro Fan Replacement: step 12, image 2 of 2
      • Gently remove the fan cable from under other wires and fully remove the fan.
      Ask FixBot
1 Guide Comment
Where did you get the replacement fan ? I'm unable to find one with the long wire connector
demint3@roadrunner.com - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 55
All Time: 735
