CHI Original Circuit Board Replacement
  1. CHI Original Circuit Board Replacement, Hinge Spring: step 1, image 1 of 2 CHI Original Circuit Board Replacement, Hinge Spring: step 1, image 2 of 2
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
    Ask FixBot
  2. CHI Original Circuit Board Replacement: step 2, image 1 of 1
    • Remove the .53" long screw from the hinge pin.
    Ask FixBot
  3. CHI Original Circuit Board Replacement: step 3, image 1 of 1
    • Remove the hinge pin.
    Ask FixBot
  4. CHI Original Circuit Board Replacement: step 4, image 1 of 1
    • Separate the two halves of the CHI Original.
    Ask FixBot
  5. CHI Original Circuit Board Replacement: step 5, image 1 of 2 CHI Original Circuit Board Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
    Ask FixBot
  6. CHI Original Circuit Board Replacement, Power Cord: step 6, image 1 of 2 CHI Original Circuit Board Replacement, Power Cord: step 6, image 2 of 2
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
    Ask FixBot
  7. CHI Original Circuit Board Replacement: step 7, image 1 of 1
    • Gently pull upwards on the connection point and disconnect the power cord.
    Ask FixBot
  8. CHI Original Circuit Board Replacement, Circuit Board: step 8, image 1 of 3 CHI Original Circuit Board Replacement, Circuit Board: step 8, image 2 of 3 CHI Original Circuit Board Replacement, Circuit Board: step 8, image 3 of 3
    • Remove the (2) .27" Phillips head screws on each half of the CHI Original.
    Ask FixBot
  9. CHI Original Circuit Board Replacement: step 9, image 1 of 3 CHI Original Circuit Board Replacement: step 9, image 2 of 3 CHI Original Circuit Board Replacement: step 9, image 3 of 3
    • Remove the covers on both halves.
    Ask FixBot
  10. CHI Original Circuit Board Replacement: step 10, image 1 of 1
    • Remove (2) .15" Phillips screws from the circuit board.
    Ask FixBot
  11. CHI Original Circuit Board Replacement: step 11, image 1 of 2 CHI Original Circuit Board Replacement: step 11, image 2 of 2
    • Desolder all points of contact between the circuit board and wires on the ceramic heating elements.
    Ask FixBot
3 other people completed this guide.
Eric Knigga
248 Reputation
2 Guides authored
IUPUI, Team S1-G2, Freund Fall 2017 Member of IUPUI, Team S1-G2, Freund Fall 2017
IUPUI-FREUND-F17S1G2
4 Members
5 Guides authored
1 Guide Comment
I used most of this guide through step 10 after dropping this in water; I didn't take out the power cord. I left the partially disassembled straightener in a container with desiccant overnight to remove the moisture. There was some corrosion on the switch that prevented the device from turning off that I cleaned up with isopropyl alcohol . I confirmed the switch behavior before and after cleaning with a multimeter to check continuity. On my device, the contact closest to the heating element was supposed to be disconnected from the other two contacts when off; when on, they were all showing contact. Before cleaning, there was continuity between all contacts. Thanks for the guide.
bnh8 - Reply Share
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 61
All Time: 4,414
