Introduction
Go to step 1 ↓This is a comprehensive guide to replacing the USB-C charging port of the CAT S62 phone.
Symptoms of a faulty charging port include:
- Extremely slow charging.
- Phone does not charge when plugged in.
- Phone begins to overheat during charging.
- Charging port is bent or otherwise damaged.
Tools
Spudger4.9
Use the plastic spudger to gently pry off the rubber back panel. If needed, use the plastic iFixit opening picks to help keep the plate separated. (Heating the back of the phone using a blow dryer may help loosen adhesive.)
Gently pull the back panel away to avoid damaging the connecting wire for the fingerprint sensor.
