Up to 20% off select tools
CAT S48c Power Button Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
77
All Time:
370
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide on how to easily replace the power button on your CAT S48c.
This guide will go through the steps to replace the power button if your CAT S48c is not turning on and your power button is damaged.
Common symptoms/indicators:
  • Button not clicking and or stuck.
  • Phone not turning on.
The replacement can be found on Ebay: OEM SPRINT CATERPILLAR CAT S48C ORIGINAL ORANGE PROGRAMMABLE BUTTON ROCKER KEY.
    1. CAT S48c Power Button Replacement, Battery: step 1, image 1 of 2 CAT S48c Power Button Replacement, Battery: step 1, image 2 of 2
      • Remove the ten T5 Torx 4 mm-long screws on the sides of the case.
      Ask FixBot
    2. CAT S48c Power Button Replacement: step 2, image 1 of 2 CAT S48c Power Button Replacement: step 2, image 2 of 2
      • Open the side covers and remove the SIM card with tweezers or a pick.
      • If there is an SD card remove that as well.
      Ask FixBot
    3. CAT S48c Power Button Replacement: step 3, image 1 of 3 CAT S48c Power Button Replacement: step 3, image 2 of 3 CAT S48c Power Button Replacement: step 3, image 3 of 3
      • Use an opening pick to pry off the rear cover.
      Ask FixBot
    4. CAT S48c Power Button Replacement: step 4, image 1 of 3 CAT S48c Power Button Replacement: step 4, image 2 of 3 CAT S48c Power Button Replacement: step 4, image 3 of 3
      • Remove the five 3 mm-long Phillips #000 screws that secure the lower midframe.
      Ask FixBot
    5. CAT S48c Power Button Replacement: step 5, image 1 of 2 CAT S48c Power Button Replacement: step 5, image 2 of 2
      • Use the tip of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    6. CAT S48c Power Button Replacement: step 6, image 1 of 3 CAT S48c Power Button Replacement: step 6, image 2 of 3 CAT S48c Power Button Replacement: step 6, image 3 of 3
      • Remove the five 3 mm-long Phillips #000 screws from the top section of the midframe.
      • Gently pry the section along with the battery off of the case.
      Ask FixBot
    7. CAT S48c Power Button Replacement: step 7, image 1 of 2 CAT S48c Power Button Replacement: step 7, image 2 of 2
      • Gently pry the battery from the case, making sure not to bend the battery.
      • Replace the battery with your replacement, popping it in the frame and insert the flex cable.
      • Keep in mind that if it has lumps or damages it could be dangerous to handle as it can catch on fire.
      Ask FixBot
    1. CAT S48c Power Button Replacement, Power Button: step 8, image 1 of 1
      • Once the battery has been removed look for the bright orange power button on the side of your phone.
      Ask FixBot
    2. CAT S48c Power Button Replacement: step 9, image 1 of 2 CAT S48c Power Button Replacement: step 9, image 2 of 2
      • You can test the button on the motherboard itself to see if it's the motherboard and not the button, if so you may need to replace the motherboard.
      • Use tweezers to remove the button.
      • Once the button is taken out replace it with your new button. You may notice rubber-like holders on the sides, make sure they line up with the frame.
      Ask FixBot
Author
with
RYAN RAMIREZ
302 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 77
All Time: 370
