Tools
Introduction
Go to step 1 ↓This is a guide to replace the battery of the CAT S48c.
If your CAT S48c isn't powering on, then this guide will help replace the battery to fix your issues. The battery is one of the main issues of a phone not charging or turning on. The battery is what powers the device and can charge once dead.
After about 500 full charge cycles, most lithium-ion batteries in phone's will die out.
Some symptoms of a battery issue are:
- Overheating
- Sudden shutdowns
- Not powering on
- Not charging
If you're dealing with a swollen battery remember to be cautious of it catching fire, and handle it on a non flammable surface.
The battery replacement can be found on Ebay, the name is OEM SPRINT CATERPILLAR CAT S48C REPLACEMENT FRAME BATTERY L6880 4070mAh 3.8V.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
