CAT S22 Flip Battery Replacement
    1. CAT S22 Flip Battery Replacement, Battery: step 1, image 1 of 1
      • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
      • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
      • The screw cannot be completely removed so that you can’t lose the screw.
      Ask FixBot
    2. CAT S22 Flip Battery Replacement: step 2, image 1 of 1
      • There is a slot on the upper left side of the back plate to insert the Spudger.
      • Use a spudger to pry up the back plate.
      Ask FixBot
    3. CAT S22 Flip Battery Replacement: step 3, image 1 of 1
      • There is a slot to insert a spudger at the bottom of the battery.
      • Use a spudger to lift the battery out of the phone.
      • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 116
All Time: 575
