Up to 20% off select tools
CAT S22 Flip Back Screen Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
109
All Time:
920
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will go over replacing the CAT 22 Flip backscreen. The back screen of the CAT S22 Flip displays time and Android widgets.
A faulty back screen may not display properly.
    1. CAT S22 Flip Back Screen Replacement, Back Screen: step 1, image 1 of 3 CAT S22 Flip Back Screen Replacement, Back Screen: step 1, image 2 of 3 CAT S22 Flip Back Screen Replacement, Back Screen: step 1, image 3 of 3
      • Insert a metal spudger into the seam of the phone frame.
      • Apply a downward force on the metal spudger to create a gap.
      Ask FixBot
    2. CAT S22 Flip Back Screen Replacement: step 2, image 1 of 1
      • Insert a jimmy into the gap.
      • Use the jimmy to wedge the front panel free from the frame.
      • There is adhesive binding the front panel to the frame, so you will have to apply a moderate amount of force to get them apart.
      Ask FixBot
    3. CAT S22 Flip Back Screen Replacement: step 3, image 1 of 1
      • Use a J00 JIS screwdriver to remove the four wide 3.3 mm-long screws.
      • Use a J00 JIS screwdriver to remove the four narrow 3.3 mm-long screws.
      Ask FixBot
    4. CAT S22 Flip Back Screen Replacement: step 4, image 1 of 2 CAT S22 Flip Back Screen Replacement: step 4, image 2 of 2
      • Use a metal spudger to dislodge the lip holding the frame together.
      Ask FixBot
    5. CAT S22 Flip Back Screen Replacement: step 5, image 1 of 1
      • Use the flat end of a spudger to gently disconnect the back screen press connector.
      Ask FixBot
    6. CAT S22 Flip Back Screen Replacement: step 6, image 1 of 1
      • Gently remove the back screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Noah White
603 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 109
All Time: 920
