CASIO mw240-1bv Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
12
Past 7 Days:
119
Past 30 Days:
458
All Time:
13,441
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your watch is running behind or the time displayed on the watch is not changing at all, it may be time to replace your battery. This guide will walk you through how to replace the battery in your CASIO mw240-1bv watch without accidently breaking something within your watch. The only tools you will need for this repair is a Phillips screwdriver, a pair of tweezers, and you may find a magnetic pad useful to keep track of the small screws.
Parts
Tools
    1. CASIO mw240-1bv Battery Replacement, Battery: step 1, image 1 of 3 CASIO mw240-1bv Battery Replacement, Battery: step 1, image 2 of 3 CASIO mw240-1bv Battery Replacement, Battery: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four screws from the back of the watch.
      • Remove the back cover of the watch.
      Ask FixBot
    2. CASIO mw240-1bv Battery Replacement: step 2, image 1 of 3 CASIO mw240-1bv Battery Replacement: step 2, image 2 of 3 CASIO mw240-1bv Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to pull the small metal piece to the right slightly to allow the battery to pop out.
      • Replace battery with a SR626SW watch battery.
      • The battery may spring out very suddenly.
      • If your battery is swollen, handle it with care and dispose of it through an e-waste center or ask an electronics store. Do not dispose of it in the garbage.
      Ask FixBot
    3. CASIO mw240-1bv Battery Replacement: step 3, image 1 of 2 CASIO mw240-1bv Battery Replacement: step 3, image 2 of 2
      • If the rubber seal pops out, realign the rubber seal with the groove along the back face.
      Ask FixBot
7 other people completed this guide.
2 Guide Comments
Thank you. I couldn't find the battery type. Much appreciated.
Templeton Peck - Reply Share
Dankeschön für die Anleitung 😊
Hat mir die Recherche-Arbeit nach der Batterie erspart.
Rafael - Reply Share
Past 24 Hours: 12
Past 7 Days: 119
Past 30 Days: 458
All Time: 13,441
