CASIO fx-570MS Battery Replacement
Views: 59K
View statistics:
Past 24 Hours:
16
Past 7 Days:
108
Past 30 Days:
441
All Time:
59,004
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
I recently had to change the battery of my Casio fx-570MS Scientific Calculator. I have been using this calculator since the 7th grade and found it difficult to part with just because the battery needed replacement.
Most engineers and aspiring engineers like myself also become very fond and attached to their equipment, including calculators.
The CASIO fx-570MS is not sold in North America, but it is a very popular model with international students coming to Canada and the United States from Asian, Middle Eastern, and North African countries. Such students will greatly appreciate a guide to replace the battery of their beloved calculator easily.
Also, most international students coming to Canada and the United States from developing countries are not in the habit of performing technical repairs while in their home countries. Semi-skilled and informal labour is readily available, often performing simple repairs at rates cheaper than buying a replacement. However, the dynamics change when in North America. Technical repairs often cost more than buying a replacement.
Given these devices' sentimental nature, as already explained, some may prefer to replace the battery and continue using their calculators. Given instructions are readily available.
Good Luck and Happy Fixing!!
Parts
Tools
    1. CASIO fx-570MS Battery Replacement, charger: step 1, image 1 of 2 CASIO fx-570MS Battery Replacement, charger: step 1, image 2 of 2
      • Flip the calculator over so the bottom is facing upwards.
      Ask FixBot
    2. CASIO fx-570MS Battery Replacement: step 2, image 1 of 3 CASIO fx-570MS Battery Replacement: step 2, image 2 of 3 CASIO fx-570MS Battery Replacement: step 2, image 3 of 3
      • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
      • Remove the battery hatch.
      Ask FixBot
    3. CASIO fx-570MS Battery Replacement: step 3, image 1 of 3 CASIO fx-570MS Battery Replacement: step 3, image 2 of 3 CASIO fx-570MS Battery Replacement: step 3, image 3 of 3
      • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
      • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
      • Caution: Be careful to not rupture the battery or damage the panel board.
      Ask FixBot
    4. CASIO fx-570MS Battery Replacement: step 4, image 1 of 3 CASIO fx-570MS Battery Replacement: step 4, image 2 of 3 CASIO fx-570MS Battery Replacement: step 4, image 3 of 3
      • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
      • Make sure the flat side of the battery is facing upwards.
      • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
      Ask FixBot
    5. CASIO fx-570MS Battery Replacement: step 5, image 1 of 2 CASIO fx-570MS Battery Replacement: step 5, image 2 of 2
      • Close the plastic hatch and secure the screw.
      Ask FixBot
    6. CASIO fx-570MS Battery Replacement: step 6, image 1 of 2 CASIO fx-570MS Battery Replacement: step 6, image 2 of 2
      • Flip the calculator on its back and press the 'ON' button to power it up.
      • A zero will appear on the bottom right corner of the LED display.
      Ask FixBot
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
3 other people completed this guide.
Saquib Ahmed
205 Reputation
1 Guide authored
1 Guide Comment
How much does the battery cost?
Tamanna - Reply Share
Past 24 Hours: 16
Past 7 Days: 108
Past 30 Days: 441
All Time: 59,004
