CASIO fx-300 MS Battery Replacement
    1. CASIO fx-300 MS Battery Replacement, Battery: step 1, image 1 of 3 CASIO fx-300 MS Battery Replacement, Battery: step 1, image 2 of 3 CASIO fx-300 MS Battery Replacement, Battery: step 1, image 3 of 3
      • Press SHIFT+AC to turn off the calculator.
      • Press the shift button, and a symbol in the top-left corner should appear. Afterward, push the AC button.
      Ask FixBot
    2. CASIO fx-300 MS Battery Replacement: step 2, image 1 of 3 CASIO fx-300 MS Battery Replacement: step 2, image 2 of 3 CASIO fx-300 MS Battery Replacement: step 2, image 3 of 3
      • Flip the calculator so the back of the device is facing up.
      • Use a Phillips #0 screwdriver to remove the six 5 mm screws.
      Ask FixBot
    3. CASIO fx-300 MS Battery Replacement: step 3, image 1 of 3 CASIO fx-300 MS Battery Replacement: step 3, image 2 of 3 CASIO fx-300 MS Battery Replacement: step 3, image 3 of 3
      • Use a spudger to pry the back case from the calculator.
      • Gently work your way around the edge of the calculator to release any clips before separating the two halves.
      • If you feel resistance when removing the back case, check to make sure you didn't miss a screw.
      Ask FixBot
    4. CASIO fx-300 MS Battery Replacement: step 4, image 1 of 3 CASIO fx-300 MS Battery Replacement: step 4, image 2 of 3 CASIO fx-300 MS Battery Replacement: step 4, image 3 of 3
      • Use a spudger to remove the old battery.
      • Replace it with a new LR44 1.5 volt battery.
      Ask FixBot
    5. CASIO fx-300 MS Battery Replacement: step 5, image 1 of 3 CASIO fx-300 MS Battery Replacement: step 5, image 2 of 3 CASIO fx-300 MS Battery Replacement: step 5, image 3 of 3
      • Reassemble the calculator and replace the 5 mm Phillips #0 screws.
      • Press the ON button to verify that the replacement was successful.
      Ask FixBot
Raphael Tweneboah
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 85
All Time: 1,522
