CASIO CDP-230R Pitch Bend Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
88
All Time:
1,080
Comments: 7
7 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Pitch bends can stop working. If you cannot hear the difference in sound when you adjust the pitch blend, it may be time to replace it. This guide will show you how to replace the pitch bend on the side panel of your device.
Tools
    1. CASIO CDP-230R Pitch Bend Replacement, Panels: step 1, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement, Panels: step 1, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement, Panels: step 1, image 3 of 3
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      Ask FixBot
    2. CASIO CDP-230R Pitch Bend Replacement: step 2, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 2, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 2, image 3 of 3
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      Ask FixBot
    3. CASIO CDP-230R Pitch Bend Replacement: step 3, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 3, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 3, image 3 of 3
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      Ask FixBot
    4. CASIO CDP-230R Pitch Bend Replacement: step 4, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 4, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 4, image 3 of 3
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      Ask FixBot
    5. CASIO CDP-230R Pitch Bend Replacement: step 5, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 5, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 5, image 3 of 3
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      Ask FixBot
    6. CASIO CDP-230R Pitch Bend Replacement: step 6, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 6, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 6, image 3 of 3
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      Ask FixBot
    7. CASIO CDP-230R Pitch Bend Replacement: step 7, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 7, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 7, image 3 of 3
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      Ask FixBot
    8. CASIO CDP-230R Pitch Bend Replacement: step 8, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement: step 8, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement: step 8, image 3 of 3
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      Ask FixBot
    1. CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: step 9, image 1 of 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: step 9, image 2 of 3 CASIO CDP-230R Pitch Bend Replacement, Pitch Bend: step 9, image 3 of 3
      • Remove the two 8mm x 1.5mm J screws from the inside of the side panel by using a J1 head screwdriver.
      • Slide the pitch bend out of the side panel.
      Ask FixBot
    2. CASIO CDP-230R Pitch Bend Replacement: step 10, image 1 of 2 CASIO CDP-230R Pitch Bend Replacement: step 10, image 2 of 2
      • Follow the white and orange cable to the white end that is attached to the button panel
      • Pinch the white end and pull the cord out
      Ask FixBot
    3. CASIO CDP-230R Pitch Bend Replacement: step 11, image 1 of 1
      • Run the white and orange cable through the innermost side panel and pull out
      Ask FixBot
Areli Reyes
545 Reputation
4 Guides authored
Cal Poly, Team S4-G2, Livingston Fall 2017 Member of Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 88
All Time: 1,080
