CASIO CDP-230R Panels Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
115
All Time:
1,554
Comments: 7
7 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the main panels off of your CASIO CDP-230R which is essential to replacing other components in your keyboard.
Tools
    1. CASIO CDP-230R Panels Replacement, Panels: step 1, image 1 of 3 CASIO CDP-230R Panels Replacement, Panels: step 1, image 2 of 3 CASIO CDP-230R Panels Replacement, Panels: step 1, image 3 of 3
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      Ask FixBot
    2. CASIO CDP-230R Panels Replacement: step 2, image 1 of 3 CASIO CDP-230R Panels Replacement: step 2, image 2 of 3 CASIO CDP-230R Panels Replacement: step 2, image 3 of 3
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      Ask FixBot
    3. CASIO CDP-230R Panels Replacement: step 3, image 1 of 3 CASIO CDP-230R Panels Replacement: step 3, image 2 of 3 CASIO CDP-230R Panels Replacement: step 3, image 3 of 3
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      Ask FixBot
    4. CASIO CDP-230R Panels Replacement: step 4, image 1 of 3 CASIO CDP-230R Panels Replacement: step 4, image 2 of 3 CASIO CDP-230R Panels Replacement: step 4, image 3 of 3
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      Ask FixBot
    5. CASIO CDP-230R Panels Replacement: step 5, image 1 of 3 CASIO CDP-230R Panels Replacement: step 5, image 2 of 3 CASIO CDP-230R Panels Replacement: step 5, image 3 of 3
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      Ask FixBot
    6. CASIO CDP-230R Panels Replacement: step 6, image 1 of 3 CASIO CDP-230R Panels Replacement: step 6, image 2 of 3 CASIO CDP-230R Panels Replacement: step 6, image 3 of 3
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      Ask FixBot
    7. CASIO CDP-230R Panels Replacement: step 7, image 1 of 3 CASIO CDP-230R Panels Replacement: step 7, image 2 of 3 CASIO CDP-230R Panels Replacement: step 7, image 3 of 3
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      Ask FixBot
    8. CASIO CDP-230R Panels Replacement: step 8, image 1 of 3 CASIO CDP-230R Panels Replacement: step 8, image 2 of 3 CASIO CDP-230R Panels Replacement: step 8, image 3 of 3
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      Ask FixBot
Areli Reyes
545 Reputation
4 Guides authored
Cal Poly, Team S4-G2, Livingston Fall 2017 Member of Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 115
All Time: 1,554
