CASIO CDP-230R Main Circuit Board Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
86
All Time:
2,801
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will teach you how to replace the main circuit board in the CASIO CDP-230R.
Tools
    1. CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 3 of 3
      • Flip the keyboard upside down, with the keys on a flat surface.
      • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
      Ask FixBot
    2. CASIO CDP-230R Main Circuit Board Replacement: step 2, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 2, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 2, image 3 of 3
      • Use two hands to grab the side panel from both sides.
      • Pull the panel apart from the device one side at a time.
      • There will be popping sounds when you remove this panel.
      • One side panel will not have an orange & white cable connected to it.
      Ask FixBot
    3. CASIO CDP-230R Main Circuit Board Replacement: step 3, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 3, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 3, image 3 of 3
      • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
      • One side panel will not have an orange & white cable running through.
      Ask FixBot
    4. CASIO CDP-230R Main Circuit Board Replacement: step 4, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 4, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 4, image 3 of 3
      • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
      • Repeat steps one through four to remove the other side panel of the keyboard.
      Ask FixBot
    5. CASIO CDP-230R Main Circuit Board Replacement: step 5, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 5, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 5, image 3 of 3
      • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
      • There will be two screws per bracket.
      Ask FixBot
    6. CASIO CDP-230R Main Circuit Board Replacement: step 6, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 6, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 6, image 3 of 3
      • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
      • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
      Ask FixBot
    7. CASIO CDP-230R Main Circuit Board Replacement: step 7, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 7, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 7, image 3 of 3
      • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
      Ask FixBot
    8. CASIO CDP-230R Main Circuit Board Replacement: step 8, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 8, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 8, image 3 of 3
      • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
      • Having a extra pair of hands will be useful.
      • Grab the center of the front panel with two hands and lift to remove panel.
      • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
      Ask FixBot
    1. CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: step 9, image 1 of 2 CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: step 9, image 2 of 2
      • The main circuit board is located on the green side of the button panel. The main circuit board is the smaller green board.
      • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
      • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver.
      Ask FixBot
    2. CASIO CDP-230R Main Circuit Board Replacement: step 10, image 1 of 1
      • Lift the main circuit board from the button panel.
      Ask FixBot
    3. CASIO CDP-230R Main Circuit Board Replacement: step 11, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 11, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 11, image 3 of 3
      • Grip the white plastic end of the orange and white cables that is attached to the right side of the main circuit board and pull to the right.
      • Repeat for the orange and white cables attached to the left side of the main circuit board and pull up.
      Ask FixBot
2 other people completed this guide.
Gavin Chao
191 Reputation
1 Guide authored
Cal Poly, Team S4-G2, Livingston Fall 2017 Member of Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Members
72 Guides authored
2 Guide Comments
Уважаемый fixit это димитрий фенетов твой чертовски мертвый
Roman Ambramovich - Reply Share
дорогой ifixit ваша ложь не является исключительной
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 86
All Time: 2,801
