C. BLV NeoPixel Board
    1. C. BLV NeoPixel Board, Flashing the NeoPixel Board: step 1, image 1 of 1
      • Disconnect the TX/RX wires from the Duet.
      • After downloading and installing the CH340 Driver from the FYSTEC Github
      • Add a jumper to "UVCC to 5V". If you skip this step you will not be able to flash the board.
      • Download the sketch from Github and extract the zip file. Open it in Arduino IDE
      • Board is "Arduino Pro or Pro Mini"
      • Processor is "ATmega328P (5V, 16 MHz)"
      • Upload the sketch to the board
      • When upload is complete, remove the jumper.
      Ask FixBot
    2. C. BLV NeoPixel Board, NeoPixel Rings: step 2, image 1 of 2 C. BLV NeoPixel Board, NeoPixel Rings: step 2, image 2 of 2
      • Left(Heatbed) connects to port #3 on the BLV NeoPixel board
      • Middle(Hotend) connects to port #1 on the BLV NeoPixel board
      • Right(print status) connects to port #2 on the BLV NeoPixel board
      Ask FixBot
    3. C. BLV NeoPixel Board, Errors Opening Sketch: step 3, image 1 of 3 C. BLV NeoPixel Board, Errors Opening Sketch: step 3, image 2 of 3 C. BLV NeoPixel Board, Errors Opening Sketch: step 3, image 3 of 3
      • You might receive an error saying you need "NeoPixel_BLV.ino needs to be in a folder named NeoPixel_BLV". You have 2 options.
      • This will create a new folder and move the sketch into the newly created folder. Click OK than close Arudino IDE. Move the highlighted files and folder into the new folder "NeoPixel_BLV". You can now reopen the sketch and it should compile without issue.
      • You can also rename the sketch's parent folder to "NeoPixel_BLV". When you open the sketch you won't receive the error.
      Ask FixBot
    4. C. BLV NeoPixel Board, Duet 3 Usage: step 4, image 1 of 2 C. BLV NeoPixel Board, Duet 3 Usage: step 4, image 2 of 2
      • Because the CH340 drives RX to ~4.5v it doesn't communicate with the Duet 3. To remedy this you need to either cut the trace or de-solder the pad on the CH340(green) or on the ATMega(red). I would suggest de-soldering the pad on the CH340 because it's easier.
      • In addition to the current wiring schematic you'll also need to to connect the TX from the Arduino to RX on the duet
      • Arduino RX > Duet 3 io1.out
      • Arduino TX > Duet 3 io1.in
      • Arduino GND > Duet 3 io1.GND
      • After the modifications you will no longer be able to upload a sketch using the USB port. You have to use a FTDI serial adapter and connect it to the 6 header pins next to the USB port.
      Ask FixBot
      • For firmware versions prior to RRF 3.4.
      • If using IO_0: M575 P1 S1 B57600.
      • If using IO_1: M575 P2 S1 B57600
      • For firmware versions RRF 3.4 and later
      • If using IO_0: M575 P1 S0 B57600.
      • If using IO_1: M575 P2 S0 B57600
      Ask FixBot
Finish Line
4 other people completed this guide.
David Husolo
9,382 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 2,775
