C-shaped Shower Door Handle Replacement
    1. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: step 1, image 1 of 3 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: step 1, image 2 of 3 C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: step 1, image 3 of 3
      • Locate the socket head cap screw on the bottom arm of one door handle.
      • Only one handle will have the cap screws—one on the top and one on the bottom arm.
      • Insert the Allen wrench into the cap screw hole.
      • Rotate the Allen wrench counterclockwise to loosen the screw.
      Ask FixBot
    2. C-shaped Shower Door Handle Replacement: step 2, image 1 of 2 C-shaped Shower Door Handle Replacement: step 2, image 2 of 2
      • Once the screw has been loosened, gently pull the handle away from the door.
      Ask FixBot
    3. C-shaped Shower Door Handle Replacement: step 3, image 1 of 1
      • Repeat steps 1 and 2 for the top of the handle.
      • Carefully remove the handle.
      Ask FixBot
    4. C-shaped Shower Door Handle Replacement: step 4, image 1 of 2 C-shaped Shower Door Handle Replacement: step 4, image 2 of 2
      • On the remaining handle, insert the Phillips #2 screwdriver into the bottom screw.
      • Turn the screwdriver counterclockwise to loosen the screw.
      • Remove the screw cap, screw, and washer.
      • There may be several parts to the screw and washer set. This example has a brass screw cap, a screw, a larger 1.25" metal washer and plastic washer, and the interior, 3/4" plastic washer.
      Ask FixBot
    5. C-shaped Shower Door Handle Replacement: step 5, image 1 of 1
      • Disassemble the screw and washer set.
      • Remove the old or damaged interior plastic washer and discard.
      Ask FixBot
    6. C-shaped Shower Door Handle Replacement: step 6, image 1 of 3 C-shaped Shower Door Handle Replacement: step 6, image 2 of 3 C-shaped Shower Door Handle Replacement: step 6, image 3 of 3
      • Slide the new plastic washer onto the screw.
      • This may require threading the washer onto the screw if the hole is snug.
      • After you have threaded the new washer, reassemble the remaining parts of the screw set in reverse order.
      Ask FixBot
    7. C-shaped Shower Door Handle Replacement: step 7, image 1 of 2 C-shaped Shower Door Handle Replacement: step 7, image 2 of 2
      • Insert the threaded screw set back through the shower door and handle.
      • Tighten the screw with the Phillips screwdriver, taking care not to overtighten or strip the screw.
      Ask FixBot
    8. C-shaped Shower Door Handle Replacement: step 8, image 1 of 1
      • Repeat steps 4-7 with the top screw.
      Ask FixBot
    9. C-shaped Shower Door Handle Replacement: step 9, image 1 of 2 C-shaped Shower Door Handle Replacement: step 9, image 2 of 2
      • Once both screws are tightened, slide the other handle back onto the screws.
      Ask FixBot
    10. C-shaped Shower Door Handle Replacement: step 10, image 1 of 2 C-shaped Shower Door Handle Replacement: step 10, image 2 of 2
      • Tighten the cap screw on the top part of the handle with the Allen wrench.
      Ask FixBot
    11. C-shaped Shower Door Handle Replacement: step 11, image 1 of 1
      • Repeat with the bottom cap screw.
      Ask FixBot
    12. C-shaped Shower Door Handle Replacement: step 12, image 1 of 1
      • Test both sides of the handle by gripping each one and gently pulling them back and forth.
      • If the handle is properly secure, there should be no movement.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 63
Past 30 Days: 324
All Time: 2,409
