Bulova Precisionist 96B252 Link Replacement
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
47
Past 30 Days:
178
All Time:
2,985
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This repair guide demonstrates how to remove and replace damaged watch links on your Bulova Precisionist 96B252. However, the steps should be similar for other watches with metal links. This guide aims to go over the process of removing the faulty watch link from the watch band and replacing it with a new one.
A watch band is sometimes composed of metal links that are connected to form the band. The links can be removed and replaced as needed using a few tools that are specific to watches. Occasionally, the links will bend, get scratched, or damaged and a replacement is necessary. This guide can also be used to remove a link if the band is too large.
    1. Bulova Precisionist 96B252 Link Replacement, Link: step 1, image 1 of 1
      • Open the watchband and locate the arrows that are on the inside edge of the band.
      Ask FixBot
    2. Bulova Precisionist 96B252 Link Replacement: step 2, image 1 of 1
      • Place the watch onto the watch holder with the arrows pointing down.
      Ask FixBot
    3. Bulova Precisionist 96B252 Link Replacement: step 3, image 1 of 2 Bulova Precisionist 96B252 Link Replacement: step 3, image 2 of 2
      • Align the 0.8 mm pin puncher to the link hole you want to remove.
      • Lightly tap the pin puncher with the soft side of the hammer until the pin comes out
      • The pin can be reused to attach the new link if it is not warped or damaged.
      Ask FixBot
    4. Bulova Precisionist 96B252 Link Replacement: step 4, image 1 of 1
      • Flip the watch so the arrows on the band are pointing up and away from the watch holder.
      Ask FixBot
    5. Bulova Precisionist 96B252 Link Replacement: step 5, image 1 of 3 Bulova Precisionist 96B252 Link Replacement: step 5, image 2 of 3 Bulova Precisionist 96B252 Link Replacement: step 5, image 3 of 3
      • Align the pinhole on the new link with the pinhole on the watch band.
      • Once the pin holes are lined up, position the pin over the holes
      • Use the soft side of the hammer to gently tap the pin into the links, connecting the new link to the watch.
      Ask FixBot
    6. Bulova Precisionist 96B252 Link Replacement: step 6, image 1 of 1
      • Once the pin is smoothly inserted into the band, try the watch on to ensure the new links are aligned and securely in place.
      Ask FixBot
To reassemble your watch, follow these instructions in reverse order.
Michael
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 178
All Time: 2,985
