Up to 20% off select tools
Buick Key Fob Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
152
All Time:
2,637
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
A quick guide to replacing the battery in a Buick key fob
This specifc guide was written for a 2019 Buick Key Fob, but should apply to most Buick Key's with push to start.
The battery is a CR2032
    1. Buick Key Fob Battery Replacement, Remove the Inner Key: step 1, image 1 of 1
      • Push the chrome button on the back of the key fob to release the inner key
      Ask FixBot
    2. Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: step 2, image 1 of 2 Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: step 2, image 2 of 2
      • Using an opening tool/pick helps avoid damage, however you can also use the inner key to pry the two shells apart
      • If using the inner key to pry them apart, just reinsert the tip of the key into fob and gently twist
      Ask FixBot
    3. Buick Key Fob Battery Replacement, Remove Old Battery: step 3, image 1 of 1
      • Slide a tool underneath the old battery to pop it out, the replacement battery goes in face down toward the bottom shell
      Ask FixBot
Author
with
Jim
331 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 152
All Time: 2,637
