Bugaboo Cameleon 1 and 3 Brake Handle Replacement
  1. Bugaboo Cameleon 1 and 3 Brake Handle Replacement, Brake Handle: step 1, image 1 of 1
    • Remove both screws on the inner side of the black plastic part, connecting the brake to the frame.
    • Make sure not to lose the screws, since you will need them for the reassembly
    Ask FixBot
  2. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 2, image 1 of 1
    • Remove the left piece that is holding the brake handle.
    Ask FixBot
  3. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 3, image 1 of 1
    • Pull the brake line down and take the brake handle out of the black plastic part.
    Ask FixBot
  4. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 4, image 1 of 1
    • Take the brake cable out of the groove in the brake handle.
    Ask FixBot
  5. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 5, image 1 of 3 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 5, image 2 of 3 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 5, image 3 of 3
    • Pry the inside part out of the brake with a flat screwdriver.
    • Inside the brakes resides a spring. This can cause the part to fly out of the brake handle when the inner part is not clammed anymore.
    Ask FixBot
  6. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 6, image 1 of 1
    • Put the spring into the replacement brake handle.
    Ask FixBot
  7. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 7, image 1 of 1
    • Insert the inner piece of the brake handle into the replacement part. You have to align the small projection on the inner piece with the hole of the brake handle.
    • Use force until the inner piece is clamped into the brake handle.
    Ask FixBot
  8. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 8, image 1 of 1
    • Insert the brake cable back into the brake handle.
    • The picture shows the brake handle without the inner parts inserted. This is not correct and you should first insert the inner pieces as shown in the previous steps before starting with this step.
    Ask FixBot
  9. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 9, image 1 of 1
    • Insert the brake handle back into the frame.
    Ask FixBot
  10. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 10, image 1 of 2 Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 10, image 2 of 2
    • Insert the black inner piece onto the brake handle.
    • Screw the screws back into the frame using the Torx screwdriver.
    Ask FixBot
  11. Bugaboo Cameleon 1 and 3 Brake Handle Replacement: step 11, image 1 of 1
    • Enjoy your new brake handle!
    Ask FixBot
Finish Line
Attached Documents
Rebecca Dowling
692 Reputation
3 Guides authored
1 Guide Comment
Nice, it looks awesome, im also missing the small plastic part, the one used to lock the brake. Do you also have the STL for that?
Thanks
andsk8 - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 3,614
