Bugaboo Cameleon 1 and 3 Handlebar Clip Replacement
  1. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: step 1, image 1 of 2 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove old part: step 1, image 2 of 2
    • Loosen the screw using the torx screwdriver.
    • Make sure to catch the nut that will fall out at the bottom, by holding the other hand underneath the clip.
    • Make sure not to lose the screw since you will need it later for the reassembly.
    Ask FixBot
  2. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement, Remove screw: step 2, image 1 of 1
    • Use the screwdriver to push the screw up and out of the black part.
    Ask FixBot
  3. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 3, image 1 of 1
    • Remove the broken handlebar clip and the small part with the spring.
    • Make sure to keep the part with the spring, since that is not included if you use the 3D model used for this repair guide.
    Ask FixBot
  4. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 4, image 1 of 2 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 4, image 2 of 2
    • Put the part with the spring back in.
    • Hold it in place while putting the new part back in place
    Ask FixBot
  5. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 5, image 1 of 2 Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 5, image 2 of 2
    • Place the torx screw back in place, and place the nut back onto the underside of the screw.
    • Hold it in place with one hand, while using the other hand to fasten the screw using the torx screwdriver.
    Ask FixBot
  6. Bugaboo Cameleon 1 and 3  Handlebar Clip Replacement: step 6, image 1 of 1
    • Adjust the handlebar according to your needs.
    • Close the clip. All done!
    Ask FixBot
Finish Line
3 other people completed this guide.
Attached Documents
Rebecca Dowling
692 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 50
All Time: 2,435
