Buffalo Linkstation mini LS-WSXL Disassembly
    1. Buffalo Linkstation mini LS-WSXL Disassembly, Remove front strip: step 1, image 1 of 2 Buffalo Linkstation mini LS-WSXL Disassembly, Remove front strip: step 1, image 2 of 2
      • Using a thin blade, gently prise the strip-sticker from the front of the unit.
      Ask FixBot
    2. Buffalo Linkstation mini LS-WSXL Disassembly, Splitting the case: step 2, image 1 of 2 Buffalo Linkstation mini LS-WSXL Disassembly, Splitting the case: step 2, image 2 of 2
      • There are two catches to release on the front face.
      • Using the iFixit opening tools, insert the first blade between the long opening and the first hole.
      • The second blade should be inserted between the third and fourth holes
      • Gently manipulate the tools to disengage the catches.
      • Open the case wider to be able to get the ifixit tools in the gap on the side of the unit - go to the next step.
      Ask FixBot
    3. Buffalo Linkstation mini LS-WSXL Disassembly, Removing the lid: step 3, image 1 of 2 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the lid: step 3, image 2 of 2
      • The first catch is next to the rubber foot. Insert the tool under the lip and lift the side to disengage the catch
      • The second catch can be found at the beginning of the vents, use the same technique to open the catch
      • Repeat the steps on the opposite side and the lid will come off.
      Ask FixBot
    4. Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: step 4, image 1 of 3 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: step 4, image 2 of 3 Buffalo Linkstation mini LS-WSXL Disassembly, Removing the hard drives: step 4, image 3 of 3
      • Pull the until out of the case, there are no catches, it is simply held in.
      • Place the unit on it's side and remove the metal plate that is clamped to the board.
      • Turn the unit over the remove the second plate.
      • The hard drives can now be removed.
      Ask FixBot
    5. Buffalo Linkstation mini LS-WSXL Disassembly, Finished!: step 5, image 1 of 2 Buffalo Linkstation mini LS-WSXL Disassembly, Finished!: step 5, image 2 of 2
      • The unit is now disassembled, assembly is simply done in the reverse order.
      • When reassembling the unit, pay attention to the orientation of the metal plates.
      Ask FixBot
2 other people completed this guide.
4 Guide Comments
I have the 2x1TB version and DID manage to successfully replace HDD's with SSD's! I only had 500GB SSD's and don't recall having any problems (but it was years ago though). I do have a number of downloaded utilities, including TFTP Boot Recovery (presumably from Buffalo website) so it's possible I had to use this (too long ago to recall)!
Andrew Blay - Reply Share
I need the TFTP Boot Recovery files. Have you the files?
Michael Gebert - Reply Share
Thanks to all...I opened it without breaking anything thanks to you.
Maurizio Spinelli - Reply Share
Put an an initialised but unformatted SSD in slot #2 and it is seen by the device but upon formatting it says "failed to operate disk. please resummit after restart". When I insert a regular HDD this message does not appear. Any idea?
Greybox - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 4,399
