Up to 20% off select tools
Brother XR-40 Lightbulb Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
107
All Time:
4,150
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
  • Zip Ties
    5
Tools
Introduction
Go to step 1 ↓
Replacing the lightbulb involves opening up the machine. You will need to purchase a sewing machine bulb set, including the wire plug-in, to replace it.
    1. Brother XR-40 Lightbulb Replacement, Back Panel: step 1, image 1 of 1
      • Place the machine on a solid surface.
      • Remove the 14mm Phillips #2 screw holding on the face cover.
      Ask FixBot
    2. Brother XR-40 Lightbulb Replacement: step 2, image 1 of 1
      • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
      Ask FixBot
    3. Brother XR-40 Lightbulb Replacement: step 3, image 1 of 1
      • Lay the machine on its side.
      • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
      • The feet will come off with the screws.
      Ask FixBot
    4. Brother XR-40 Lightbulb Replacement: step 4, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
    5. Brother XR-40 Lightbulb Replacement: step 5, image 1 of 1
      • Place the machine upright.
      • Remove the rear casing.
      • You may have to wiggle the panel and pull at the same time.
      Ask FixBot
    1. Brother XR-40 Lightbulb Replacement, Lightbulb: step 6, image 1 of 1
      • Using scissors, clip the two zip ties securing the lightbulb wire.
      Ask FixBot
    2. Brother XR-40 Lightbulb Replacement: step 7, image 1 of 1
      • Place the machine on its side, with access to the bottom.
      • Gently pull out the white wire connecting the bulb to the machine.
      Ask FixBot
    3. Brother XR-40 Lightbulb Replacement: step 8, image 1 of 1
      • Move the wire out from under the plastic hook.
      Ask FixBot
    4. Brother XR-40 Lightbulb Replacement: step 9, image 1 of 1
      • Using the flathead screwdriver, remove the 5mm Flathead screw holding on the lightbulb bracket.
      Ask FixBot
    5. Brother XR-40 Lightbulb Replacement: step 10, image 1 of 1
      • Remove the lightbulb assembly.
      Ask FixBot
Author
with
Kevin Bickers
673 Reputation
4 Guides authored
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 107
All Time: 4,150
