Up to 20% off select tools
Brother XR-40 Back Panel Disassembly
Views: 13K
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
165
All Time:
13,192
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this step we will be removing the rear casing from the sewing machine. This is necessary to access the inside components of the machine.
    1. Brother XR-40 Back Panel Disassembly, Back Panel: step 1, image 1 of 1
      • Place the machine on a solid surface.
      • Remove the 14mm Phillips #2 screw holding on the face cover.
      Ask FixBot
    2. Brother XR-40 Back Panel Disassembly: step 2, image 1 of 1
      • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
      Ask FixBot
    3. Brother XR-40 Back Panel Disassembly: step 3, image 1 of 1
      • Lay the machine on its side.
      • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
      • The feet will come off with the screws.
      Ask FixBot
    4. Brother XR-40 Back Panel Disassembly: step 4, image 1 of 1
      • Remove the bottom panel.
      Ask FixBot
    5. Brother XR-40 Back Panel Disassembly: step 5, image 1 of 1
      • Place the machine upright.
      • Remove the rear casing.
      • You may have to wiggle the panel and pull at the same time.
      Ask FixBot
5 other people completed this guide.
Author
with
Allison
302 Reputation
2 Guides authored
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 165
All Time: 13,192
