Brother XM3700 Broken Needle Replacement
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: step 1, image 1 of 3 Brother XM3700 Broken Needle Replacement, Broken Needle: step 1, image 2 of 3 Brother XM3700 Broken Needle Replacement, Broken Needle: step 1, image 3 of 3
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
    Ask FixBot
  2. Brother XM3700 Broken Needle Replacement: step 2, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 2, image 2 of 2
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
    Ask FixBot
  3. Brother XM3700 Broken Needle Replacement: step 3, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 3, image 2 of 2
    • Remove the broken needle stem from the machine, and dispose of it carefully.
    Ask FixBot
  4. Brother XM3700 Broken Needle Replacement: step 4, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 4, image 2 of 2
    • Unthread the broken needle tip from the thread, and dispose of carefully.
    Ask FixBot
  5. Brother XM3700 Broken Needle Replacement: step 5, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 5, image 2 of 2
    • Select a Brother brand needle, using the needle size that works well with your fabric.
    Ask FixBot
  6. Brother XM3700 Broken Needle Replacement: step 6, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 6, image 2 of 2
    • Insert the needle with the flat side of the stem facing the back of the machine.
    Ask FixBot
  7. Brother XM3700 Broken Needle Replacement: step 7, image 1 of 1
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
    Ask FixBot
  8. Brother XM3700 Broken Needle Replacement: step 8, image 1 of 2 Brother XM3700 Broken Needle Replacement: step 8, image 2 of 2
    • Rethread the needle and pull the thread through the back.
    Ask FixBot
Congratulations! You have successfully replaced your broken needle. Happy sewing!
Nadya Verick
178 Reputation
1 Guide authored
UC Davis, Team 1-6, Andersen Winter 2023 Member of UC Davis, Team 1-6, Andersen Winter 2023
UCD-ANDERSEN-W23S1G6
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 42
All Time: 932
