Brother PT-D200 LCD Screen Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
115
All Time:
2,786
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a dead or broken LCD screen on a Brother PT-D200.
Tools
    1. Brother PT-D200 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Ask FixBot
    2. Brother PT-D200 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the six AAA batteries.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, Back of Device: step 3, image 1 of 1
      • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
      Ask FixBot
    2. Brother PT-D200 LCD Screen Replacement: step 4, image 1 of 1
      • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
      • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, Circuit Board Cables: step 5, image 1 of 1
      • Gently pull out the ribbon cable from the circuit board.
      • The ribbon cable is very fragile.
      Ask FixBot
    2. Brother PT-D200 LCD Screen Replacement: step 6, image 1 of 1
      • Remove two-pin plastic connector from the circuit board.
      • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, Circuit Board: step 7, image 1 of 2 Brother PT-D200 LCD Screen Replacement, Circuit Board: step 7, image 2 of 2
      • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
      Ask FixBot
    2. Brother PT-D200 LCD Screen Replacement: step 8, image 1 of 1
      • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
      Ask FixBot
    3. Brother PT-D200 LCD Screen Replacement: step 9, image 1 of 1
      • Disconnect the LCD ribbon cable from the circuit board.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, Face Plate: step 10, image 1 of 1
      • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
      Ask FixBot
    2. Brother PT-D200 LCD Screen Replacement: step 11, image 1 of 2 Brother PT-D200 LCD Screen Replacement: step 11, image 2 of 2
      • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, Keyboard: step 12, image 1 of 2 Brother PT-D200 LCD Screen Replacement, Keyboard: step 12, image 2 of 2
      • Peel off the rubber keyboard of the device.
      Ask FixBot
    1. Brother PT-D200 LCD Screen Replacement, LCD Screen: step 13, image 1 of 2 Brother PT-D200 LCD Screen Replacement, LCD Screen: step 13, image 2 of 2
      • Lift the LCD screen out of place.
      Ask FixBot
Jeston Mitchell
308 Reputation
3 Guides authored
Cal Poly, Team 13-16, Regan Winter 2014 Member of Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 115
All Time: 2,786
