Up to 20% off select tools
Brother PT-D200 Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
85
All Time:
1,220
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will lead you through the steps for replacing the keyboard on your Brother PT-D200.
    1. Brother PT-D200 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Ask FixBot
    2. Brother PT-D200 Keyboard Replacement: step 2, image 1 of 1
      • Remove the six AAA batteries.
      Ask FixBot
    1. Brother PT-D200 Keyboard Replacement, Back of Device: step 3, image 1 of 1
      • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
      Ask FixBot
    2. Brother PT-D200 Keyboard Replacement: step 4, image 1 of 1
      • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
      • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
      Ask FixBot
    1. Brother PT-D200 Keyboard Replacement, Face Plate: step 5, image 1 of 1
      • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
      Ask FixBot
    2. Brother PT-D200 Keyboard Replacement: step 6, image 1 of 2 Brother PT-D200 Keyboard Replacement: step 6, image 2 of 2
      • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
      Ask FixBot
    1. Brother PT-D200 Keyboard Replacement, Keyboard: step 7, image 1 of 2 Brother PT-D200 Keyboard Replacement, Keyboard: step 7, image 2 of 2
      • Peel off the rubber keyboard of the device.
      Ask FixBot
Author
with
[deleted]
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 85
All Time: 1,220
