Brother PT-D200 Faceplate Replacement
    1. Brother PT-D200 Faceplate Replacement, Battery: step 1, image 1 of 1
      • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
      Ask FixBot
    2. Brother PT-D200 Faceplate Replacement: step 2, image 1 of 1
      • Remove the six AAA batteries.
      Ask FixBot
    1. Brother PT-D200 Faceplate Replacement, Back of Device: step 3, image 1 of 1
      • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
      Ask FixBot
    2. Brother PT-D200 Faceplate Replacement: step 4, image 1 of 1
      • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
      • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
      Ask FixBot
    1. Brother PT-D200 Faceplate Replacement, Circuit Board Cables: step 5, image 1 of 1
      • Gently pull out the ribbon cable from the circuit board.
      • The ribbon cable is very fragile.
      Ask FixBot
    2. Brother PT-D200 Faceplate Replacement: step 6, image 1 of 1
      • Remove two-pin plastic connector from the circuit board.
      • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
      Ask FixBot
    1. Brother PT-D200 Faceplate Replacement, Face Plate: step 7, image 1 of 1
      • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
      Ask FixBot
    2. Brother PT-D200 Faceplate Replacement: step 8, image 1 of 2 Brother PT-D200 Faceplate Replacement: step 8, image 2 of 2
      • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
      Ask FixBot
[deleted]
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,155
