Brother PT-D200 Cutter Blade Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
138
All Time:
4,783
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a dull or broken cutter blade on a Brother PT-D200.
    1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: step 1, image 1 of 2 Brother PT-D200 Cutter Blade Replacement, Cutter Blade: step 1, image 2 of 2
      • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
      Ask FixBot
    2. Brother PT-D200 Cutter Blade Replacement: step 2, image 1 of 1
      • Locate the cutter blade unit (mint green) as shown in the picture.
      Ask FixBot
    3. Brother PT-D200 Cutter Blade Replacement: step 3, image 1 of 2 Brother PT-D200 Cutter Blade Replacement: step 3, image 2 of 2
      • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
      • The blade is sharp.
      Ask FixBot
Blaire McCreary
201 Reputation
2 Guides authored
Cal Poly, Team 13-16, Regan Winter 2014 Member of Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
3 Members
72 Guides authored
2 Guide Comments
Where can you order the replacement blade?
mistymeziere - Reply Share
Thank you it, the blade came out and I did not know how to fix this.. found this video and quickly fixed it..
niva - Reply Share
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 138
All Time: 4,783
