Brother PT-90 Personal Labeler Disassembly
    1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: step 1, image 1 of 2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: step 1, image 2 of 2
      • Start with your device off. The screen should be blank and not displaying anything.
      • Turn the device over so it's resting face down.
      • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
      Ask FixBot
    2. Brother PT-90 Personal Labeler Disassembly: step 2, image 1 of 3 Brother PT-90 Personal Labeler Disassembly: step 2, image 2 of 3 Brother PT-90 Personal Labeler Disassembly: step 2, image 3 of 3
      • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
      • Remove the 4 batteries located on the left side of the device.
      Ask FixBot
    3. Brother PT-90 Personal Labeler Disassembly: step 3, image 1 of 3 Brother PT-90 Personal Labeler Disassembly: step 3, image 2 of 3 Brother PT-90 Personal Labeler Disassembly: step 3, image 3 of 3
      • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
      Ask FixBot
    4. Brother PT-90 Personal Labeler Disassembly: step 4, image 1 of 3 Brother PT-90 Personal Labeler Disassembly: step 4, image 2 of 3 Brother PT-90 Personal Labeler Disassembly: step 4, image 3 of 3
      • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
      • Remove all of the screws from the back of the device.
      Ask FixBot
    5. Brother PT-90 Personal Labeler Disassembly: step 5, image 1 of 2 Brother PT-90 Personal Labeler Disassembly: step 5, image 2 of 2
      • Once the screws have been removed, press as shown on the fastener.
      • Carefully open the device.
      Ask FixBot
Finish Line
2 other people completed this guide.
Tessa Hathaway
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 75
All Time: 1,682
