Brother PT-210 Cutter Blade Replacement
    1. Brother PT-210 Cutter Blade Replacement, Back Cover: step 1, image 1 of 3 Brother PT-210 Cutter Blade Replacement, Back Cover: step 1, image 2 of 3 Brother PT-210 Cutter Blade Replacement, Back Cover: step 1, image 3 of 3
      • Use the tab to open the back cover of your machine.
      Ask FixBot
    1. Brother PT-210 Cutter Blade Replacement, Tape: step 2, image 1 of 2 Brother PT-210 Cutter Blade Replacement, Tape: step 2, image 2 of 2
      • Remove the tape by grabbing the tape and pulling it up & out of your machine.
      Ask FixBot
    2. Brother PT-210 Cutter Blade Replacement, New Tape: step 3, image 1 of 1
      • If you are going to use a new tape, you have to turn the green knob counterclockwise a few times to get the tape ready to use.
      Ask FixBot
    1. Brother PT-210 Cutter Blade Replacement, Remove Cutter Blade: step 4, image 1 of 3 Brother PT-210 Cutter Blade Replacement, Remove Cutter Blade: step 4, image 2 of 3 Brother PT-210 Cutter Blade Replacement, Remove Cutter Blade: step 4, image 3 of 3
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • This is the cutter blade.
      • WARNING: The cutter blade is sharp
      • Pull this up and out with your fingers or a spudger.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. For a new cutter blade if you need one, just look on Amazon.
TheMasterG
1,430 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 59
All Time: 512
