Brother PT-1290 Face Plate Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
94
All Time:
602
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide, you will see how to fix your broken/damaged face plate on your Brother PT-1290.
Tools
    1. Brother PT-1290  Face Plate Replacement, Keyboard: step 1, image 1 of 3 Brother PT-1290  Face Plate Replacement, Keyboard: step 1, image 2 of 3 Brother PT-1290  Face Plate Replacement, Keyboard: step 1, image 3 of 3
      • Turn the device to its side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
      Ask FixBot
    2. Brother PT-1290  Face Plate Replacement: step 2, image 1 of 3 Brother PT-1290  Face Plate Replacement: step 2, image 2 of 3 Brother PT-1290  Face Plate Replacement: step 2, image 3 of 3
      • Remove back of device and set aside.
      Ask FixBot
    3. Brother PT-1290  Face Plate Replacement: step 3, image 1 of 3 Brother PT-1290  Face Plate Replacement: step 3, image 2 of 3 Brother PT-1290  Face Plate Replacement: step 3, image 3 of 3
      • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
      Ask FixBot
    4. Brother PT-1290  Face Plate Replacement: step 4, image 1 of 3 Brother PT-1290  Face Plate Replacement: step 4, image 2 of 3 Brother PT-1290  Face Plate Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
      Ask FixBot
    5. Brother PT-1290  Face Plate Replacement: step 5, image 1 of 3 Brother PT-1290  Face Plate Replacement: step 5, image 2 of 3 Brother PT-1290  Face Plate Replacement: step 5, image 3 of 3
      • Use a spudger to aid in removing the keyboard.
      • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
      Ask FixBot
    1. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: step 6, image 1 of 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: step 6, image 2 of 3 Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: step 6, image 3 of 3
      • Now that you have removed your keyboard. Turn the device over carefully.
      • Pop of LCD black cover.
      • Use the spudger to gently press out the LCD screen.
      Ask FixBot
    2. Brother PT-1290  Face Plate Replacement, Switching out faceplate.: step 7, image 1 of 1
      • Change out old damaged face plate with your new face plate.
      Ask FixBot
Lorraine Canez
318 Reputation
3 Guides authored
Gateway, Team 1-4, Johnson Fall 2014 Member of Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 94
All Time: 602
