Brother PT-1010 Cutter Blade Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
105
All Time:
1,993
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Brother PT-1010 Cutter Blade Replacement, Remove Back Cover: step 1, image 1 of 1
      • Open the back cover of the device by pressing on the indication arrow and pulling it open.
      Ask FixBot
    2. Brother PT-1010 Cutter Blade Replacement, Locate Cutter Blade Unit: step 2, image 1 of 1
      • Locate the yellow cutter blade unit as shown in the photo.
      Ask FixBot
    3. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 1 of 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 2 of 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 3 of 3
      • Using your thumb and forefinger, pull up, applying a small amount of pressure until the blade loosens and comes out.
      • Be very careful when pulling out the cutter blade, it is very sharp.
      • The Brother no. TL 5 Cutter Blade Unit is required for replacement.
      Ask FixBot
Haley Sweet
460 Reputation
4 Guides authored
Baylor, Team 4-4, Williams Fall 2014 Member of Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 105
All Time: 1,993
