Brother PT-1010 Battery Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
96
All Time:
5,483
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Brother PT-1010 requires 6-AAA batteries. The batteries are organized in two layers one on top of the other. This guide will inform you on proper battery replacement.
    1. Brother PT-1010 Battery Replacement, Removing Back Panel: step 1, image 1 of 1
      • Turn device so you are looking down at the top
      Ask FixBot
    2. Brother PT-1010 Battery Replacement: step 2, image 1 of 2 Brother PT-1010 Battery Replacement: step 2, image 2 of 2
      • Press firmly on arrow indicator and pull panel toward you.
      Ask FixBot
    3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: step 3, image 1 of 1
      • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
      • Make sure the battery compartment is empty and clear of debris.
      Ask FixBot
    4. Brother PT-1010 Battery Replacement: step 4, image 1 of 2 Brother PT-1010 Battery Replacement: step 4, image 2 of 2
      • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
      • Do the same thing to insert the next 2 batteries.
      Ask FixBot
    5. Brother PT-1010 Battery Replacement: step 5, image 1 of 1
      • The next 3 batteries will be inserted on top of the others.
      • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
      Ask FixBot
    6. Brother PT-1010 Battery Replacement: step 6, image 1 of 1
      • Repeat step 5 to insert the last 2 batteries.
      Ask FixBot
    7. Brother PT-1010 Battery Replacement, Replace Back Panel: step 7, image 1 of 1
      • Reinsert back panel.
      Ask FixBot
Haley Sweet
460 Reputation
4 Guides authored
Baylor, Team 4-4, Williams Fall 2014 Member of Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 96
All Time: 5,483
