Brother MFC-9130CW Ink Cartridge Replacement
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: step 1, image 1 of 1
    • Press the power button on the printer for a couple of seconds to turn it off.
    Ask FixBot
  2. Brother MFC-9130CW Ink Cartridge Replacement: step 2, image 1 of 2 Brother MFC-9130CW Ink Cartridge Replacement: step 2, image 2 of 2
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
    Ask FixBot
  3. Brother MFC-9130CW Ink Cartridge Replacement: step 3, image 1 of 1
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
    Ask FixBot
  4. Brother MFC-9130CW Ink Cartridge Replacement: step 4, image 1 of 2 Brother MFC-9130CW Ink Cartridge Replacement: step 4, image 2 of 2
    • Pull each ink cartridge tray out of its slot using the center handle.
    Ask FixBot
  5. Brother MFC-9130CW Ink Cartridge Replacement: step 5, image 1 of 2 Brother MFC-9130CW Ink Cartridge Replacement: step 5, image 2 of 2
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
    Ask FixBot
  6. Brother MFC-9130CW Ink Cartridge Replacement: step 6, image 1 of 2 Brother MFC-9130CW Ink Cartridge Replacement: step 6, image 2 of 2
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
    Ask FixBot
  7. Brother MFC-9130CW Ink Cartridge Replacement: step 7, image 1 of 3 Brother MFC-9130CW Ink Cartridge Replacement: step 7, image 2 of 3 Brother MFC-9130CW Ink Cartridge Replacement: step 7, image 3 of 3
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
    Ask FixBot
  8. Brother MFC-9130CW Ink Cartridge Replacement: step 8, image 1 of 1
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
    Ask FixBot
To reassemble your device, follow these instructions in the given order.
Kamaljot
184 Reputation
1 Guide authored
1 Guide Comment
One step is missing : release the orange cover.
Artefil - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 878
