Up to 20% off select tools
Brother IntelliFax-2840 Control Panel Replacement
Views: 5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
97
All Time:
4,969
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a damaged or malfunctioning control panel on your Brother IntelliFax-2840. The entire panel is replaced as a unit, including the buttons and display.
    1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: step 1, image 1 of 1
      • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
      Ask FixBot
    2. Brother IntelliFax-2840 Control Panel Replacement: step 2, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 2, image 2 of 2
      • Gently pull the ADF up and away from the machine.
      Ask FixBot
    1. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: step 3, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: step 3, image 2 of 2
      • Gently lift up the control panel.
      Ask FixBot
    2. Brother IntelliFax-2840 Control Panel Replacement: step 4, image 1 of 3 Brother IntelliFax-2840 Control Panel Replacement: step 4, image 2 of 3 Brother IntelliFax-2840 Control Panel Replacement: step 4, image 3 of 3
      • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
      • Repeat for the left side control arm.
      • You can make this task easier by taking the handset out of the cradle and setting it aside.
      Ask FixBot
    3. Brother IntelliFax-2840 Control Panel Replacement: step 5, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 5, image 2 of 2
      • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
      • Lifting from the front edge, gently flip up the control panel.
      Ask FixBot
    4. Brother IntelliFax-2840 Control Panel Replacement: step 6, image 1 of 1
      • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
      Ask FixBot
    5. Brother IntelliFax-2840 Control Panel Replacement: step 7, image 1 of 1
      • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
      • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
      Ask FixBot
    6. Brother IntelliFax-2840 Control Panel Replacement: step 8, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 8, image 2 of 2
      • Separate the rear control panel cover from the control panel.
      Ask FixBot
    7. Brother IntelliFax-2840 Control Panel Replacement: step 9, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 9, image 2 of 2
      • Gently pull the control panel cable straight out from its connector.
      • The control panel should now come free.
      Ask FixBot
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 97
All Time: 4,969
