Up to 20% off select tools
Brother CS6000i Thread Cutter Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
95
All Time:
601
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 55 seconds - 6 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will be showing you how to remove and replace the thread cutter on a Brother CS6000i sewing machine. The thread cutter is a handy feature that allows the user to safely and easily cut the excess thread from the machine and workpiece. Some symptoms related to a faulty thread cutter are the thread not cutting when attempting to use the cutter (dull blade) or the thread cutter being overly exposed and no longer safe due to a broken blade enclosure.
    1. Brother CS6000i Thread Cutter Replacement, Thread Cutter: step 1, image 1 of 2 Brother CS6000i Thread Cutter Replacement, Thread Cutter: step 1, image 2 of 2
      • Take off the the white cover on the front left side.
      Ask FixBot
    2. Brother CS6000i Thread Cutter Replacement: step 2, image 1 of 3 Brother CS6000i Thread Cutter Replacement: step 2, image 2 of 3 Brother CS6000i Thread Cutter Replacement: step 2, image 3 of 3
      • Remove the 8 mm Phillips #2 screw securing the thread cutter to the housing.
      Ask FixBot
Author
with
Ava Martinez
448 Reputation
4 Guides authored
Cuesta, Team 20-1, Krynen Fall 2024 Member of Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 95
All Time: 601
