Brother CS6000i Sewing Needle Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
97
All Time:
694
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide teaches the user how to remove and replace the sewing needle for the Brother CS6000i. The needle is responsible for stitching threads into whatever material the user works on.
A replacement for the sewing needle is needed in the case where it is either stuck, dulled, or bent. Be careful not to bend it during the replacement process. To ensure the needle doesn't fall during screwing and unscrewing, hold it with one hand until it is finally released.
    1. Brother CS6000i Sewing Needle Replacement, Sewing Needle: step 1, image 1 of 2 Brother CS6000i Sewing Needle Replacement, Sewing Needle: step 1, image 2 of 2
      • Unscrew the needle clamp located above and to the right of the sewing needle.
      • Remove the needle by pulling down at the base.
      Ask FixBot
To input a new sewing needle, follow these instructions in reverse order.
Gavin Vella
73 Reputation
1 Guide authored
Cuesta, Team 20-1, Krynen Fall 2024 Member of Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 97
All Time: 694
