Brother CS6000i LCD Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
73
All Time:
563
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will be showing you how to replace the LCD screen on a Brother CS6000i sewing machine. The LCD screen helps the user identify what sewing mode and speed they are working with. Some common symptoms particularly related to a faulty LCD screen would be faulty diodes or a blank screen while the machine is in operation.
Before beginning make sure power is disconnected and needle is removed from machine to prevent injury from electrical shock and or sharp objects.
Tools
    1. Brother CS6000i LCD Screen Replacement, Body: step 1, image 1 of 2 Brother CS6000i LCD Screen Replacement, Body: step 1, image 2 of 2
      • Remove the five 20 mm Phillips #2 screws on the back of the device.
      • Remove the single 28 mm Phillips #2 screw on the back of the device.
      • Remove the single 23 mm Phillips #2 screw on the back of the device.
      Ask FixBot
    2. Brother CS6000i LCD Screen Replacement: step 2, image 1 of 2 Brother CS6000i LCD Screen Replacement: step 2, image 2 of 2
      • Pull the white cover off.
      Ask FixBot
    3. Brother CS6000i LCD Screen Replacement: step 3, image 1 of 2 Brother CS6000i LCD Screen Replacement: step 3, image 2 of 2
      • Remove the final screw, a 11 mm Phillips #2.
      • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
      Ask FixBot
    4. Brother CS6000i LCD Screen Replacement: step 4, image 1 of 3 Brother CS6000i LCD Screen Replacement: step 4, image 2 of 3 Brother CS6000i LCD Screen Replacement: step 4, image 3 of 3
      • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
      • Unhook the white wires that are connected to the motherboard.
      • Fully separate the two halves.
      Ask FixBot
    1. Brother CS6000i LCD Screen Replacement, LCD Screen: step 5, image 1 of 1
      • Remove the two 10 mm Philips #2 screws that secure the screen.
      • Unplug the ribbon cable located at the top of the circuit board, then gently remove the LCD screen.
      Ask FixBot
Wasim Benbrahim
152 Reputation
1 Guide authored
Cuesta, Team 20-1, Krynen Fall 2024 Member of Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 73
All Time: 563
