Broken Zipper On Luggage Replacement
  1. Broken Zipper On Luggage Replacement, Zipper: step 1, image 1 of 1
    • Remove the metal stopper at the end with the pliers (which ever set works for your size zipper), using a bit of pressure to pry it off of the slider. This will help the current, broken zipper come off easier.
    Ask FixBot
  2. Broken Zipper On Luggage Replacement: step 2, image 1 of 1
    • Dismantle the current, broken zipper on the slider. To do this, you'll need to use pliers. Apply pressure vertically to pry the zipper away from the teeth of the slider.
    • Use the other pair of pliers to keep the zipper in place while you remove it. It should then smoothly slide off of the slider.
    Ask FixBot
  3. Broken Zipper On Luggage Replacement: step 3, image 1 of 1
    • Install the new zipper. To do this, simply slide the new zipper over the end of the slider chain in the same direction than the old one. This should secure the teeth together for a comfortable fit.
    Ask FixBot
  4. Broken Zipper On Luggage Replacement: step 4, image 1 of 1
    • Applying pressure, use pliers to reattach the metal zipper stopper.
    Ask FixBot
  5. Broken Zipper On Luggage Replacement: step 5, image 1 of 1
    • Secure the new zipper, using the pliers, setting the stoppers back in place and molding it back together.
    Ask FixBot
Mold and bend the stopper, using the pliers, to set the stopper back in place.
6 other people completed this guide.
4 Guide Comments
Thank you. I am about to try this. A few suggestions— you say we need a screwdriver but don’t actually describe using it. It would helpful to identify the three parts of the zipper— the pull , the slider train and the stop—right at the beginning, and be consistent throughout.
aurora - Reply Share
Thanks for trying to help but you seem to miss out all the critical (difficult) steps. I have read the guide and still have no better idea of what to do.
Simon Bird - Reply Share
what is a slider chain?
Janet Angelo - Reply Share
These recommendations are completely incomprehensible. I recommend a visit to the Zipper Rescue website.
David Hammel - Reply Share
Past 24 Hours: 21
Past 7 Days: 149
Past 30 Days: 669
All Time: 178,581
