Broil-King BBQ Heat Indicator Replacement Guide
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
92
All Time:
1,801
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Extreme weather expedites the normal wear-and-tear of the Broil-King 3 burner BBQ lid heat indicator. Since it is an outdoor grill, it is susceptible to damage from being exposed to harsh elements including rain, snow, wind, cold, and excessive heat. Prolonged exposure can cause the gauge to fail, reducing the usability of the BBQ. Replacing the heat indicator creates a few ounces of recyclable trash rather than the 3 foot by 4 foot BBQ itself. This quick fix is well worth the cost savings in many ways.
Parts
Tools
    1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: step 1, image 1 of 3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: step 1, image 2 of 3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: step 1, image 3 of 3
      • Gather the tools and parts needed for the repair:
      • Crescent Wrench
      • Scraper
      • Replacement Heat Indicator
      • Be sure that the grill is completely cool and disconnect any gas tanks before beginning the repair.
      Ask FixBot
    2. Broil-King BBQ Heat Indicator Replacement Guide: step 2, image 1 of 2 Broil-King BBQ Heat Indicator Replacement Guide: step 2, image 2 of 2
      • Open the lid and then remove the nut securing the heat indicator.
      • Use a crescent wrench to loosen the nut.
      • Continue to unthread the nut with your fingers.
      • Place the nut in a secure location for later use.
      Ask FixBot
    3. Broil-King BBQ Heat Indicator Replacement Guide: step 3, image 1 of 2 Broil-King BBQ Heat Indicator Replacement Guide: step 3, image 2 of 2
      • Close the lid.
      • Slide the flat edge of the paint scraper under the existing heat indicator plate to pry the plate loose.
      • Lift the plate up, then off of the predrilled holes.
      Ask FixBot
    4. Broil-King BBQ Heat Indicator Replacement Guide: step 4, image 1 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 4, image 2 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 4, image 3 of 3
      • Push the heat indicator from the back to remove it from the Broilmate plate.
      Ask FixBot
    5. Broil-King BBQ Heat Indicator Replacement Guide: step 5, image 1 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 5, image 2 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 5, image 3 of 3
      • Align the new heat indicator through the front of the plate.
      • Move your thumbs around the plate until the heat indicator is secure.
      Ask FixBot
    6. Broil-King BBQ Heat Indicator Replacement Guide: step 6, image 1 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 6, image 2 of 3 Broil-King BBQ Heat Indicator Replacement Guide: step 6, image 3 of 3
      • Align the new heat indicator and plate with the factory drilled holes on the face of the BBQ.
      • Hold the plate in place while opening the lid.
      Ask FixBot
    7. Broil-King BBQ Heat Indicator Replacement Guide: step 7, image 1 of 2 Broil-King BBQ Heat Indicator Replacement Guide: step 7, image 2 of 2
      • Retrieve the nut used on the previous heat indicator (remember you put it in a secure location).
      • Thread the nut on the new heat indicator.
      • Use a crescent wrench to finish tightening the nut on the new bolt.
      Ask FixBot
    8. Broil-King BBQ Heat Indicator Replacement Guide: step 8, image 1 of 1
      • Close the lid. You're done!
      Ask FixBot
This simple repair doesn’t take much time, yet is well worth the effort. A working heat indicator provides the necessary information about the temperature to ensure safe food practices, and produce a tasty outcome.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 92
All Time: 1,801
