Up to 20% off select tools
Brightsign 4k Outer Shell Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
62
All Time:
721
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will take you through the process of removing the motherboard of the device in order to get access to components located underneath.
    1. Brightsign 4k Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 Brightsign 4k Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 Brightsign 4k Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
      • Remove three 8mm screws from the left side of the device.
      • Remove four 8mm screws from the right side of the device.
      Ask FixBot
    2. Brightsign 4k Outer Shell Replacement: step 2, image 1 of 3 Brightsign 4k Outer Shell Replacement: step 2, image 2 of 3 Brightsign 4k Outer Shell Replacement: step 2, image 3 of 3
      • Apply pressure on the SD card to pop it out of the port.
      • Remove the card by pulling it out.
      Ask FixBot
    3. Brightsign 4k Outer Shell Replacement: step 3, image 1 of 3 Brightsign 4k Outer Shell Replacement: step 3, image 2 of 3 Brightsign 4k Outer Shell Replacement: step 3, image 3 of 3
      • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
      • Lift the top cover off.
      Ask FixBot
    4. Brightsign 4k Outer Shell Replacement: step 4, image 1 of 3 Brightsign 4k Outer Shell Replacement: step 4, image 2 of 3 Brightsign 4k Outer Shell Replacement: step 4, image 3 of 3
      • Slide the body case back away from the bottom.
      • Pull up the body case to remove it from the bottom.
      Ask FixBot
2 other people completed this guide.
Author
with
Zackery
347 Reputation
2 Guides authored
USF Tampa, Team S17-G6, Boczar Spring 2018 Member of USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 62
All Time: 721
