Introduction
This guide will take you through the process of properly removing the motherboard of the device. Removal of the motherboard is necessary to access additional components that may need fixing.
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
