Tools
Introduction
Go to step 1 ↓If the device's LED display is not working, follow this guide to replace the LED display on your BrightSign 4k player.
Tech Tip: this Replacement guide will require the use of a soldering iron to remove solders, so check out the soldering guide if you're unfamiliar with the process.
Remove three 8mm screws from the left side of the device.
Remove four 8mm screws from the right side of the device.
Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
Turn the motherboard over and locate the solders holding the LED Display in place.
Use the soldering iron to desolder the sixteen solder joints and remove the melted solder with the pump shown in Step 8.
Tool used on this step:Desoldering Pump$3.99
Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
After the solders have been removed, gently pull the LED Display from the motherboard.
